electronics problems
bertus
Joined Apr 5, 2008
22,278
What did you do yourself?
Where did you get stuck?
From the question list:
2 Find the resistivity of n – type germanium at 300K with a donor concentration,​
Nd= 5x10 17 atoms/m3.​
Given: μ n = 3900 cm2/V-s, e = 1.6 x 10 -19 C.​
3 A Si diode carries a current of 10 mA when a forward bias of 0.72 V is applied​
at 300K (27 ° C). Find​
i. The reverse saturation current​
ii. The bias voltages required for diode currents of 1 mA and 100​
mA. Comment on these two voltages.​
iii. Reverse saturation current at 57 ° C.​
4 The primary is connected to the power mains: 220V, 50Hz. The turns ratio of a​
transformer used in a half- wave rectifier is such that the peak voltage across​
the secondary winding of a transformer is 18V. Assuming the diode resistance​
in forward bias to be zero. Calculate the (i) dc voltage across the load (ii) value​
of ac voltage across the load.​
5 a. Calculate the value of I E in a transistor for which β = 50 and I B = 15 μ A. [1]​
b. Why is collector current slightly less than emitter current?​
Bertus
