Electronics Class HELP please!
Discussion in 'General Electronics Chat' started by titanman76, Oct 12, 2008.
Thread Status:
Not open for further replies.
  1. titanman76
    Oct 11, 2008
    5
    I have some test questions I could really use some help with. If anybody is familiar with Schaums Outline basic circuit analysis. The numbers I need help with are below as well as the link to the book?
    5.67 and 5.72. I need the calculations to solve the problems. The link to the book is below. You will need to cut and paste the link together if this works.
    http://books.google.com/books?id=EPb1COh2AQUC&pg=PA275&lpg=PA275&dq=
    schaum's+basic+circuit+analysis+5.67&
    source=web&ots=e9YHAVhC4c&sig=yFRnBjBmgiME3VBKkTbMy45IWDk&hl=en&sa=X&oi=
    book_result&resnum=1&ct=result#PPA105,M1
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    I have re-enabled this thread at your request.
    hgmjr
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    I took a stab at searching for the problem with google book search and it appears that one of the problems involves delta-to-y conversion.
    Here is a link to the section of the aac ebook covering the related topic.
    Hope this helps.
    hgmjr
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Problem 5.67: If you take a look at the material at the link I have provided, you will find the equations for transforming the delta network into its equivalent Y network. Once you have the Y network values you can then combine them with the existing Y network. Once you have combined the two Y networks, you will have a simple two loop network that you can then solve the circuit with whatever method you wish to use.
    hgmjr
  5. hgmjr
    Jan 28, 2005
    9,030
    214
    Hint for problem 5.71.
    hgmjr
Thread Status:
