Electronically triggering push-button system
Discussion in 'The Projects Forum' started by Zatnikitelman, Jun 7, 2008.
  1. Zatnikitelman
    Thread Starter Active Member
    Jul 17, 2005
    31
    Sorry I couldn't come up with a more descriptive title, but it's the best I could do.
    I have one of the 9v Radioshack recordable sound modules and I need a way of electronically triggering the sound to play. The problem however is that the play button is one of those that use a conductive button to bridge a grid-like pattern of wires completing the circuit. For my project however, I need to be able to "push" this button electronicaly without using any sort of mechanical linkage. If you need an example, take apart a standard TV remote control, those have the same kind of contacts I'm talking about.
    My soldering skills aren't to the point where I could do the SMT-level soldering required to put wire on there so I can extend the contacts to a proper push-button.
    Thanks for any help you can provide
    Thanks!
    Zatnikitelman
  2. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Check out the CD4066 or 4016 quad bilateral switch chips....
  3. Zatnikitelman
    Jul 17, 2005
    31
    I'm sorry, but I'm not sure what those are. I've googled them, but with no luck.
  4. JUAN DELA CRUZ
    May 27, 2008
    121
    Hi Zatnikitelman...:)
    I think you need a 'touch activated switch' just like this:
    When the P.B. switch is press, the relay will close (ON) the ckt. & to open (OFF) the ckt., press the P.B. switch. once again.
    I hope it helps you out...
  5. Zatnikitelman
    Jul 17, 2005
    31
    I'm not sure what the circuit you show would do in this situation. If it comes to simply engaging a circuit with one push, then dis-engaging it with another, I've got that covered, but thanks for the effort.
    I've uploaded two pics showing my problem. The first shows the button in its out-of-the-box format while the second picture shows the "grid" of wires I was talking about.
    Thanks for any help!
    Zatnikitelman
  6. Zatnikitelman
    Jul 17, 2005
    31
    I hate to bump, but does anyone have a solution?
  7. RiJoRI
    Aug 15, 2007
    536
    26
    I solder like I'm using a flame thrower, but if I was in this quandary, I would carefully scrape of the conformal coating on the two lands leading to the "switch fingers," and very carefully solder two wires there. I could then run those wires to my controller (the 4066).
    For info on the 4066, see ALLDATA.COM http://www.alldatasheet.com/datasheet-pdf/pdf/8175/NSC/4066.html
    HTH,
    --Rich
  8. ixisuprflyixi
    Sep 16, 2007
    52
    I agree with Ri the simplest solution seems to be to solder the wires onto the board. Do not doubt yourself. You can clean the leads of the green protective layer where the copper traces are thicker and therefore easier to solder. OR.. using a DMM on continuity mode trace each side of that switch to find the solder joint they terminate at ( if there is one) and solder to that, hopefully larger, solder joint.
