Electronically controlling PWM
Discussion in 'General Electronics Chat' started by peck68, Apr 5, 2010.
  1. peck68
    Nov 27, 2009
    73
    hmm right, i have made my first PWM (yay :)) but i want to expand it further - however, I do not want to use picaxe's since the programming board is around £40 and I dont want to spend that ;)
    So here is the PWM - what I want it to do is sweep from a low duty cycle (since i noticed that it doesn't actually go fully off, but very dim) to maximum, hold it there for a second or two and then come back and hold.
    Any ideas? Do digital potentiometers exsist?
    Oh and please don't take me back to LEDs, 555s, Flashers, and Light Chasers - I've read it enough times ;)
    thanks
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Don't look at figure 4.3 in post #6 of that thread you don't want to look at, because replacing the resistive divider (R4 thru R6) with a variable voltage will do what you want to do.
    But since you don't want to look at that thread again, I don't know what to tell you.
    I guess forget about building the circuit? :D
  3. peck68
    Nov 27, 2009
    73
    Eh was that in it?!
    I've read through it like 4 times haha - okay thanks i will read post #6 ;)
    Will post if i need more help :)
    edit:
    I cant find figure 4.7? Only 5.1, 4.2 and 4.3
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, I'm blind. :rolleyes:
    I meant figure 4.3; the last figure in post #6
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Look at fig 4.3 of that thread.
    (SgtWookie probably mistyped the number).
    There you will find a 555 with an opamp to create a PWM signal.
    Bertus
  6. peck68
    Nov 27, 2009
    73
    Hmm so I think I understand now :)
    (correct me)
    So as the voltage increases from the triangle wave of the 555, the lm339 output gets brighter, and vice versa when it decreases?
    And what is the PNP transistor for? Is the output a negative voltage?
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Q1, R7 and D1 are there for visualizing the PWM.
    If you do not want to check it visualy you can leave them out.
    R8 is a must as the LM339 comparator has an open collector output.
    Bertus
  8. pilko
    Dec 8, 2008
    213
    20
    By the way, PICAXES do not need a programming board.
    Regards
    pilko
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    The LM393 is also a good alternate for the comparator, the LM339 is a quad, the LM393 is a dual. Both require a resistor going to Vcc as they are open collector. Ground the input pins of the unused comparators.
  10. peck68
    Nov 27, 2009
    73
    How can they be programmed without one? (would save me lots of dosh :D)
    So was my understanding correct? (that it varies the output with the determined triangle wave) - does it go from 0% to 100% or is it say 33 to 66? (1/3Vs and 2/3Vs)
  11. pilko
    Dec 8, 2008
    213
    20
    Check picaxeforum.co.uk, click on Picaxe manuals at top of page, read manual 1. It explains why the Picaxe does not need a programmer.
    That is one of the big advantages of the Picaxe.
    Regards
    pilko
  12. peck68
    Nov 27, 2009
    73
    I found this I assume:
    I did a bit of googling and i found a circuit (i think)
    Would that allow me to program it fine? Except, I hear the 16F84 doesn't have serial interface
