Electronic version of a Rotary switch?
Discussion in 'General Electronics Chat' started by guardado, Oct 26, 2012.
  1. guardado
    Sep 28, 2012
    7
    Does there exist a chip that basically gives the function of a rotary? A relay that can do this?
    The switch should ideally have 60 positions, but I should be able to do a cascade.
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    What kind of signal do you want to switch?
    Is it an analog signal or a power signal?
    How many "positions" should the switch have?
    Bertus
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
    try a CD4016
  4. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Now you tell us for 60 positions, but not what kind of signal is to be switched.
    Bertus
  5. guardado
    Sep 28, 2012
    7
    Sorry, I had to pull out some information I thought might be useful. I'm looking at DC signals from 10-110 kHz, and up to 10 volts but more likely 1.
  6. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    You could have a look at the 4051 - Analogue multiplexer/demultiplexer (1-of-8 switch)
    or an 4067 - 16-channel analogue multiplexer/demultiplexer (1-of-16 switch)
    Bertus
  7. IC-Man
    Jan 3, 2012
    26
    using a Hall based encoder or a position sensor, like the iC-MA or iC-MP from iC-Haus, the resolution can reach 8-, or also 12-bit(like the iC-MH). Here you find datasheet and application notes: http://www.ichaus.biz/keyword/Magnetic Encoder iCs
  8. atferrari
    Jan 6, 2004
    2,666
    784
    CD4066 is the improved version of the old CD4016.
    There are as well the CD4051, CD4052 and CD4053.
