Electronic test set question
Discussion in 'General Electronics Chat' started by AHMARAFAH, Jan 23, 2007.
  1. AHMARAFAH
    Jul 11, 2006
    20
    Hi every body,
    I work with electronic test set to fix my PCB cards faulty.This test set has max. speed of 15mhz.the question i want to ask is what this speed imply??????,and also,is this test set has the ability to test PCBs which used for RF transimission in a good manner or not???????
    Thanks in advance
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Most likely, it means that the fastest logic clock signal runs at 15 MHz.
    Working with RF generally means having controlled impedances and resonant circuits with the means of adjusting (tuning) them. A logic tester will not have this ability. It will not be suited for RF work at all.
