Forgive me if this is a stupid question, I'm not an electrical person, I'm a mechanical engineer...
I'm building a system to run some tests, which requires a heater to be automatically turned on and off. The coding is done through LabView, and is is currently running on a NI myDAQ. The problem is the output ports don't supply the current necessary to get the heater to its proper output. I have an external power source I can use. The power source is NOT, however, one that can interface with the computer, just physical controls. Is there any way to build a circuit that will turn the power from the source on and off to the heater using a voltage signal from the myDAQ?
