Electronic Spirit Level for 5th wheel
Discussion in 'The Projects Forum' started by RobbJohnson, Nov 3, 2014.
  1. RobbJohnson
    Thread Starter Active Member
    Dec 15, 2009
    76
    I am looking to replace my large bubble level on the front of my fifth wheel trailer. It is large so you can see it in the rear view mirror. It is calibrated to show if the wheels (left and right) which are 96" apart are out of level by 1-1/2" or 3", this is so you know how many 2*4's to put under the low wheel.
    I would like to use LEDs and a micro-controller to do this. my concern is what to use for the leveling I.C.
    it seems to me it should be a single axis gyro, but I see that 3 axis accelerometers will do this to, (must have a static mode)?
    Would appreciate any help or comments.
    Thanks, Robb
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    I don't think electronic gyro or accelerometers will do what you want. Maybe a potentiometer with a pendulum arm, feeding an LM3914 LED bar/dot display or a microcontroller to an LED display.
    Ken
  3. MrChips
    Oct 2, 2009
    12,636
    3,454
    DickCappels likes this.
  4. RobbJohnson
    Dec 15, 2009
    76
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Then you want to search for "inclinometer"...generally not cheap.
    Ken
  6. MrChips
    Oct 2, 2009
    12,636
    3,454
  7. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    My iphone 4s has a compass app that does a levelling function when you put the phone on its edge. Maybe you could somehow use that for levelling your trailer... if you have an extra iphone.
    What device are they using in a phone for levelling? The things they put in phones today.:rolleyes:
    Ifixit
  8. DNA Robotics
    Member
    Jun 13, 2014
    135
    33
  9. jpanhalt
    Jan 18, 2008
    5,699
    909
    Sears sells a torpedo level for $32 list (http://www.sears.com/craftsman-digi...a=00948295000P&kpid=00948295000&mktRedirect=y )
    I got one of those for about $25 without the laser a few years back. It is quite sensitive. I harvested the accelerator from it (Memsic MXD2020). It is quite sensitive and ±0.5° around level is easy to attain. Noise at rest is less than ±0.2°. I am currently using that sensor in a remote leveling device, which uses an XBee transmitter/receiver for a serial link.
    The MXD2020 (100 Hz version) is a bit difficult to source, but it has nice specifications.
    John
  10. Lestraveled
    May 19, 2014
    1,957
    1,218
    I like KMoffetts suggestion of a potentiometer and a pendulum. You can easily scale the output to display inches. You could use a DVM or put in a digital panel meter to display your info.
  11. RobbJohnson
    Dec 15, 2009
    76
    I have ordered some mma7361 3 axis accel. I will post my results.
  12. RobbJohnson
    Dec 15, 2009
    76
    prototype is working well. simple circuit. just used the a to d converter in the micro and turned on leds.
    working on the packaging now.
  13. Bernard
    Aug 7, 2008
    4,240
    414
    Thanks for your report, we'r looking forward to final prt.
