How can I mimick a momentary pressing of a normally closed dead-man's switch on a permanent change of signal from low to high without triggering a 555 oneshot or something that complex??
A transistor won't work, because I need full collector-emmitter current both before base voltage change (when low), and after the base voltage change (permanently high after this transition)..
