Hi I am new to here and just came across your thread and found it interesting as I myself decided to build a Snakes & Ladders board game.Kamustasas to all,. since my first project was too complicated, I come up with new proposal but still I need the help of you guys,.. I want to create a snake and ladder board which uses a 7-segment roller as dice then a light representing each player, eg. (player1=red, player 2=green, both player in one cube=blue).. when a botton is pushed the dice roll then the light automaticaly moves corresponding to the 7 segmet displayed number. then when someone stop at snake or ladder cube the light also goes to the directed cube.
This was all just an Idea so i don't have anything yet in regard to this project, soo please I need all the help I can get,.. ;'(
I have done few research and I found a circuit for the 7-segment dice,. that's all I have,.. soo please please,.. HEELLLPP!!!
any suggestion to make it simplier is also acceptable...
TNX GUYS! AiMeE\m/(0_0)\m/
At the minute I have a Snakes & Ladders board Made from MDF bought from a toy shop, I have drilled holes in each square and inserted RGB LEDs all wired up and I have the 7 Segment desplays inserted with on/off switch, reset Switch and and a switch to play the game. The Blue led lights up the Snakes & Ladders and the Red Led player A and the Green led player B. I am using x 2 555, 4510 and 4511. All fine at this stage so now the fun begins with the Logic from the 3 Binary outputs.
