New here. Just have to say, I discovered the online textbook here a couple days ago and I'm enjoying it so far.
But right now I'm having a problem with a bipolar stepper motor drive circuit. At speeds of ~3,500pps the motor stalls.
I'm using a PIC microcontroller for controlling step rate and direction, The big Easy Driver is my motor controller (seen here https://www.sparkfun.com/products/10735), and my motor is a LIN Engineering 211-18-01 (seen here http://www.linengineering.com/LinE/contents/stepmotors/211.aspx). I am running it with a 24V 0.6A unregulated power supply.
The PIC program ramps up the speed from 0-6,000pps, full step mode. At low speeds it runs great, however as soon as I get around 3500pps the motor stalls. From the motors datasheet, I can see that with the right driver it can reach speeds of ~15,000pps.
I have seen the term 'electrical resonance' on the forums, and how it occurs in the 2k-5k pps range. I believe this is my problem, however, I cannot find any more info on what exactly it is, how to find it, or how to fix it.
Does anyone know more about electrical resonance it stepper motors? Or, is this even the problem?
Thanks in Advance
Thanks in Advance
