Electronic Recomendations
Discussion in 'General Electronics Chat' started by jamers, Oct 26, 2008.
  1. jamers
    Jan 24, 2008
    12
    Gentleman
    What I'm looking for is to take a signal from a 555 timer, and "count" it for 6 counts, and vary the output on each of the 6 counts.
    After those 6 times I want it to reset and go back to the beginning.
    Forgive me for not being more specific, I am just looking to see if there is anything like this available.
    This is my conception of what it would look like.
    count signal ---> count 1 output
    ---> count 2 output
    ---> count 3 output
    ---> count 4 output
    etc etc.
    Is there any IC or anything which can do anything like this?
    Thanks.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, not quite sure what you mean by "vary the output on each of the 6 counts". :confused:
    A while back, I drew up a schematic for a fellow who wanted a timer circuit that could change pulsewidths on every count. Didn't use a 555 timer, but a 4093 Schmitt-trigger NAND gate as an astable multivibrator, with a 4017 Johnson counter to select different pulsewidths for the next time duration.
    See the attached.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Looking at it I believe a 555 would work.
