Electronic Puzzle Cube
rspuzio
Joined Jan 19, 2009
77
> Is there a discernible pattern?
> I haven't calculated it myself, so I would be guessing too.
A while back, in response to a similar discussion on the
Planet Physics discussion forum, I solved the problem for
hypercubes of arbitrary dimension. The method used is
the one described here of reducing it to a series-parallel
problem by using symmetry to identify equipotential nodes.
If we make a coordinate system with the center of the
hypercube of length 2 as origin and it edges parallel to
the coordinate axes, then the coordinates of the vertices
will all be either +1 or -1. Hence, the vertices of an
n-dimensional hypercube may be labeled by n-tuplets
of + and - and two vertices are the endpoints of an edge
if and only if their tuplets differ in exactly one slot. As the opposite
vertices between which we will consider the resistance
we may, without loss of generality, take as (+++++...) and
(-----...); put the former at a potential of 1 volt and
ground the latter. Then we note that any two vertices
whose tuplets have the same number of plus and minus
signs can be transformed into each other by a symmetry
operation which preserves the two vertices between which
we are measuring the resistance hence, by symmetry, they
will all be at the same potential.
Hence, the problem is equivalent to one in which we
collapse all the vertices at the same potential into a
single vertex. In this case, that is a problem in which
there are number of resistors between one node and the
next node in parallel. By replacing the parallel resistors
with their equivalents, all that is left is to sum series
resistors.
Since the resistors all have the same value (say 100
Ohms because that seems to be the standard value for
making resistor cubes) , we only need to count how many
resistors are between adjacent collapsed nodes --- if we
have m resistors in parallel, the resistance between those
two nodes will be 1/m hectoohms.
Before doing this in general, let me revisit the case of
3 dimensions using this notation. In three dimensions,
the vertices of our cube are labelled ---, --+, -+-, +--,
-++, +-+, ++-, +++. Arranging them by number of
plusses and writing the edges between them, we have
0 plusses: ---
3 edges: --- to --+; --- to -+-; --- to +--
1 plus: --+ -+- +--
6 edges: --+ to -++; --+ to +-+; -+- to -++;
-+- to +-+; +-- to +-+; +-- to ++-
2 plusses : -++, +-+, ++-
3 edges: -++ to +++; +-+ to +++; ++- to +++
3 plusses: +++
Hence, the total resistance is 1/3 + 1/6 + 1/3 = 5/6 hΩ as
we know well.
Now we return to the general problem of the n-dimensional
hypercube. By basic combinatorics, we know that there are
\( {n \choose k} \) ways to make a string of k plus
signs and n-k minus signs, hence we have \( {n \choose k} \)
vertices whose labels have k plus signs. Given a vertex with
k plus signs, there are k edges connecting it to vertices with
k-1 plus signs because we can make an edge by changing any
one of the k minus signs. For instance, if we look at the
vertex +-+, we can either change the first + to get the edge
from +-+ to --+ or the second + to get the edge from
+-+ to +--. Hence, there are \( {n \choose k} \)
edges connecting vertices with k plusses to vertices with
k-1 plusses. In the 3 dimensional example, we have
\( 1 \cdot {3 \choose 1} = 1 \cdot 3 = 3 \)
\( 2 \cdot {3 \choose 2} = 2 \cdot 3 = 6 \)
\( 3 \cdot {3 \choose 3} = 3 \cdot 1 = 3 \)
which agrees with the explicit enumeration above.
Making the series-parallel combination in general,
we thus have:
\( R = \sum_{k=1}^n {1 \over k {n \choose k}} \)
Expressing the binomial coefficients in terms of
factorials and tidying up, this can also be written as
\( R = {1 \over n!} \sum_{k=1}^n (n-k)! (k-1)! \)
Here is a table of values:
n R
2 1 100.0 Ω
3 5/6 ≈ 83.33 Ω
4 16/24 = 2/3 ≈ 66.67 Ω
5 64/120 = 8/15 ≈ 53.33 Ω
6 312/720 = 13/30 ≈ 43.33 Ω
7 1812/5040 = 151/420 ≈ 35.95 Ω
8 12288 /40320 = 32/105 ≈ 30.48 Ω
9 95616/362880 = 83/315 ≈ 26.35 Ω
I would have to admire the tenacity of anyone
who would hook up \(2^9\) resistors
into a hypercube arrangement ;)
steveb
Joined Jul 3, 2008
2,436
Nice solution rspuzio!
I hope I don't destract anyone from looking at your great work, but I'm going to jump in here and mention something else.
I'm glad you resurected this old thread, because I'm looking for test problems to solve. Yesterday Tesla23 was good enough to recommend a free symbolic math program called Maxima. So far it's proving to be very good, so I thought I would show how quickly this problem is solved with this tool.
The following code does it for the general case with 12 different valued resistances. You just enter in the equations in whatever form you prefer and then use the solve funtion to get the solution.
Rich (BB code):
e1:Iin=I1+I2-I3;
e2:I1=(Vin-V1)/R1;
e3:I2=(Vin-V2)/R2;
e4:I3=(V3-Vin)/R3;
e5:V1=V6+I4*R4;
e6:V2=V4+I8*R5;
e7:V3=V4+I6*R6;
e8:I4=I1-I7;
e9:V6=V3-I5*R7;
e10:V4=I12*R8;
e11:I8=I2-I10;
e12:I6=-I3-I5;
e13:I7=(V1-V5)/R9;
e14:I12=I8+I6;
e15:I10=(V2-V5)/R10;
e16:I5=I9-I4;
e17:I11=I7+I10;
e18:V5=I11*R11;
e19:I9=V6/R12;
solve([e1,e2,e3,e4,e5,e6,e7,e8,e9,e10,e11,e12,e13,e14,e15,e16,e17,e18,e19],[Vin,I1,I2,I3,V1,V2,V3,I4,V6,V4,I8,I6,I7,I12,I10,I5,I11,V5,I9]);
If the resistors are all different, the solution is pages and pages long, and can't be displayed here. However, if all resistors are equal to R, the solution for the input voltage Vin for an injected current source Iin is
\( Vin=\frac{5\,Iin\,R}{6}\) which agrees with the various more elegant methods shown in this thread.
For anyone that doesn't already have a symbolic math program, and doesn't want to spend a lot of money buying Mathamatica or Maple, I recommend the following site to get downloads of this free version of Maxima with a GUI interface. I've downloaded the Mac version and the PC version and they both seem to work great so far.
http://wxmaxima.sourceforge.net/wiki/index.php/Main_Page
The Electrician
Joined Oct 9, 2007
2,970
n R
2 1 100.0 Ω
3 5/6 ≈ 83.33 Ω
I did calculate some of the higher order hypercubes after posting my question, and discovered the same thing you did, that there is no particular pattern of repeating digits in the decimal representation of the resistance. Up to order order 6 it's just a chance occurrence.
