Electronic power supplies
Discussion in 'General Electronics Chat' started by boatsman, Apr 22, 2016.
  1. boatsman
    Thread Starter Senior Member
    Jan 17, 2008
    165
    394
    I had an emergency led lamp consisting of 120 5mm white leds. The unit was powered by a rechargeable 12v 2Ah lead battery. When the battery finally packed in I removed it and via a plug-in connection attached a mains power supply giving 12v at 2A. This worked fine. Then to make the system more compact I replaced the power supply with a lightweight switching power supply as used to power a 12v external hard disk. The leds lit up alright at the beginning and then the lights started flashing. My query is why does this happen? Surely if there is enough continuous power from one of these units to drive the motor in an external hard disk then why do the leds flash?
  2. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi b,
    Have you measured the actual led lamp current drawn from the 12V 2Ahr battery.?
    E
  3. boatsman
    Jan 17, 2008
    165
    394
    @ericgibbs
    I never checked the actual led lamp current drawn from the battery. But why would that be important if I'm using a power supply with a similar output? I am assuming that the flashing effect that I get is a result of using a switched mode power supply instead of the usual transformer supply, but why does this happen?
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    It's possible that the SMPS has been optimistically rated (Chinese 'Amps'?) and can't manage the LED load continuously, so is going into self-protect mode when it overheats.
  5. ericgibbs
    Jan 29, 2010
    2,605
    396
    hi b,
    The 2AHr rating is the Ampere-hour capacity.
    ie:
    If the battery was specified as 2Ahr at 1Amp, this would mean that the battery could supply 1Amp for 2 hours or say 2Amps for 1 hour.
    If the draw current was say 5Amps, the battery would be 'exhausted' after approx 0.4 hours.
    Note: the actual relationship between duration of the Ahr rating and current drawn is not linear, the higher the current the shorter the duration.
    E
    Check out this AAC link.
    http://www.allaboutcircuits.com/textbook/direct-current/chpt-11/battery-ratings/
  6. boatsman
    Jan 17, 2008
    165
    394
    @Alec_t and ericgibbs
    Thank you both for your replies. All we need now is a Welsh flag, or St George!
  7. ericgibbs
    Jan 29, 2010
    2,605
    396
    Its an old English battle flag.;)
    E
  8. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,711
    1,302
    Hard drives are not nearly as hungry as they were 5 or 10 years ago, and it is entirely possible that the switcher is seeing an overload/overcurrent condition, shutting down, then auto-restarting, seeing an overcurrent, shutting down... What is the rating on the lightweight switching power supply label?
    ak
