Electronic Newbie Needs Help With Integrated Light Layout
Discussion in 'The Projects Forum' started by __Z__, Apr 26, 2011.
Thread Status:
Not open for further replies.
  1. __Z__
    Apr 26, 2011
    Hey guys so im new here, I actually joined after having some problems coming up with a integrated tail light layout for my motorcycle, so i was hoping you guys could help me out....
    here is the BASIC idea
    i want to make a scanning integrated tail light board, i had just planned on using a simple bread board.
    with 10 90,000mcd red leds on the top row for running lights, as well as brake lights, these would be the ones that scan back and forth for running lights, and then 10 90,000mcd yellow leds on the bottom row 5 per turn signal (left and right)
    basically below here is how i had originally planned on doing it, however after talking to a few friends they say that i should do it another way, so please let me know what you guys think
    this is how i had planned on doing it from the power i would go to a resistor, then go to this
    http://www.bakatronics.com/shop/item.aspx?itemid=345
    from here i would only use 5 of the six connections then put in another set of resistors one perwire to go to 10 red leds... 2 leds per wire...
    here is the link to the leds i plan on using
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
    and that would be my running lights
    for the brake lights i had planned on using a relay to take power away from the running lights, i would need a different set of resistors for this since they need to be bright than the running lights
    as for the signals i just need to wire the leds to resistors, and then to the power
    i plan on using 10 red leds on to for brake and running
    and 10 yellow leds on bottom 5 per turn signal
    IF YOU CAN THINK OF THE BEST WAY TO DO THIS LET ME KNOW I realize this is quite possibly not the best way to go about this another friend mentioned a microchip to get the scanning effect vs the pre made contraption i linked...
    here is the scanning effect i want for the running light
    http://www.youtube.com/watch?v=a6LG5SnQrF0
    any help you guys can give me would be greatly appreciated, but while i have the idea, i cannot carry it out unless i get some higher electronic knowledge
    thanks guys
  2. russpatterson
    Member
    Feb 1, 2010
    351
    16
    I think they have some policy about not doing vehicle lights on here for obvious safety reasons.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We do, in fact. We can't discuss this.
Thread Status:
