What would be the advantage? I don't see it. I want to keep the parts count is low, distributing and dumping heat is the biggest problem. Everything in this unit, including the high amperage resistors, is going to get hot. Fortunately most of the use for this will be of relatively short duration, though I can see the possibility of using this for a long term burn in. I may need to add a wall wart power in as an alternate.
The 10A switch is part of the current measurement as well as the range select.
