Electronic Help
Discussion in 'Homework Help' started by fastcharlie2, Oct 16, 2014.
  1. fastcharlie2
    Oct 16, 2014
    Trying to calculate AC Vout. I did the DC analysis but dont know where to start the AC.
  2. b1u3sf4n09
    Member
    May 23, 2014
    115
    14
    Can you please show us what work you have done?
  3. fastcharlie2
    Oct 16, 2014
    I took the capacitor as an open and did a KVL from the 2V sourece to the 1.2kohm.
    -Vb+Vbe+Ie(100+1.2k)=0
    Ie=(2-.70/(100+1.2k)=1mA
    Ie is approximate to Ic, Ic=1mA
    Then a KVL at the output
    -10V+1k x Ic+Vout=0
    Vout=9V
    The only thing I know for AC analysis is re=25mV/Ie=25ohm
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    One would need to know the source frequency since there are frequency dependent components in series with the source.
  5. fastcharlie2
    Oct 16, 2014
    The frequency is from 1kHz to 100kHz. But I dont understand how to do the AC analysis of this circuit.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Are you able to draw the small signal AC equivalent circuit? This is essentially a grounded base configuration. How would you know that it is grounded base?
  7. fastcharlie2
    Oct 16, 2014
    I got it like this for the AC small signal but what do I got to do next?
