Electronic Devices II Help
Discussion in 'Homework Help' started by Pairaalia, Nov 11, 2004.
  1. Pairaalia
    Nov 11, 2004
    Hello. I have a major question...it's kind of big.
    For my Electronic Devices II class, we are supposed to build a Wien-Bridge Oscillator.
    If someone could help my out by explaining to me, some certain things to look out for so I don't blow anything up (i'm doing this at home and not at school) that would be great.
    Thanks a lot.
    -Jason
  2. mozikluv
    Jan 22, 2004
    1,437
    hi,
    if you are going to make a circuit board make sure that you don't have shorted foil path. supply polarity should be check 1st before turning on the unit. if you are using jfets make sure that you don't exceed the current rating of the device. there are other things to be considered but you have not mentioned what devices you will use. :)
