electronic dazer
Discussion in 'The Projects Forum' started by darshelectro, May 19, 2007.
  1. darshelectro
    Jan 22, 2007
    5
    i have ordered the components, to have ago at making the electronic dazer on this web site:
    http://www.uoguelph.ca/~antoon/circ/hv/dazer/dazer.htm
    When the parts arrived, the capacitor in the picture on the website is much larger than the capacitor that i have got. The capacitor that i have got is 0.1 uf radial monolithic capacitor and is about 4mm across. However the capacitor on the website is about 15 mm across.
    1) Is 0.1uf capacitor on the website the correct size, or has someone made an error, because i can not get the circuit to work?
    2) Does it make any difference if i make this on a bread board or not?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Are you confident that all the connections are correct?
    hgmjr
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Physical size of C1 is not important. Different materials and construction methods account for different physical sizes. If you have a 0.1uF cap with sufficient working voltage, you have what you need.
    Double check connections, as HGMjr has suggested. Check to see if the oscillator is working - if so, the problem is in your voltage multiplier. If not, the problem is in the oscillator.
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    Well, you should check the voltage rating of your capacitor. If is has the same capacity but is smaller, then it may have a lower voltage rating.
    Also, building this project in a breadboard may be hazardous, since most certainly there will be isolation faults. I would not advice it.
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The oscillator would be quite safe to breadboard. Any isolation problems would occur only in the voltage multiplier.
  6. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
  7. Kris Olenski
    Nov 14, 2007
    Have you tried using a disposable camera for you 'dazer"?
