There were two question 1ohm and 1kohm
In 1ohmit was 12A in 1Kohm it was 12mA
Now we're concerned with the question -- as stated -- in the below linked image:There were two question 1ohm and 1kohm
Please think about it!Yes, the circuit is working fine.
Because, The current is flowing in all branches.
The 12A rating on Ampermeter is maximum value ??12 Amps each
The indicator readings are, in effect, one of the stipulations -- So yes The current through each indicator=12A...The 12A rating on Ampermeter is maximum value ??
or
Is it showing the measuring current?
Correct! --- Please note that your entire difficulty owed to a misunderstanding of the questionIt may be R4 because of it whole current is going through all ammeter
You effortlessly and correctly solved the problem once you understood the question - IOW Good Job!Yes, to understand?
This was the question but there was no mention of current there is G may new technical term.Do you see how my example relates your first question?
If you see that relationship ... you should be able to answer questions two and three without assistance.
In this Problem what does 20 Vac mean?In a 20 Vac series RC circuit, if 20 V is measured across the resistor and 40 V is measured across the capacitor, the applied voltage is:
'G' denominates a factor of 1*10^9This was the question but there was no mention of current there is G may new technical term.
Thread starter | Similar threads | Forum | Replies | Date |
Pull down Resitor vaule for npn transistor | General Electronics Chat | 6 | ||
Question,help with sinusoidal voltage | Homework Help | 17 | ||
M | OP amp question. Calculate the gain vi/vo. | Homework Help | 1 | |
A electronic circuit question ! | General Electronics Chat | 30 | ||
An Electronic Welder Circuit Question | General Electronics Chat | 3 |
