AM4=12AWhat would each of the meters read if R4 was, say, 1 Ω and all of the others were, say, 1 kΩ?
AM3=0.012A+12A=12.012A
AM2=12.012A+0.012A=12.024A
AM1=12.024A+0.012A=12.036A
Yes.Which, if any, of these results are somewhat similar to what the meters are showing in the problem?
I can't find.Ok ...which fault condition caused the readings you saw on the diagram?
What would each of the meters read if R2 was, say, 1 Ω and all of the others were, say, 1 kΩ?
@RRITESH KAKKARAM4=0.012A
Then please show your workyes i have done that only.
This was the question where there is 1ohm the current will be 12Amps similar to this when 1K current will beWhat would each of the meters read if R1 was, say, 1 Ω and all of the others were, say, 1 kΩ?
What would each of the meters read if R3 was, say, 1 Ω and all of the others were, say, 1 kΩ?
JoeJester said:Ok ...which fault condition caused the readings you saw on the diagram?
You may wish to rethink your response -- that was not a 'yes or no' question...Yes.
The current capability of the power supply is irrelevant in the context of this exercise...This was the question where there is 1ohm the current will be 12Amps similar to this when 1K current will be
V=I*R
12/1k=12mA
The circuit is working fine yes.You may wish to rethink your response -- that was not a 'yes or no' question...
So, what is wrong ?The current capability of the power supply is irrelevant in the context of this exercise...
AM4=12mAWhat would each indicator show if the resistances of all four resistors = 1KΩ???
Yes! That is correct assuming each resistance = 1KΩ - As I mistakenly asserted -- So, Score that as a correct reply!!!AM4=12mA
AM3=24mA
AM2=36mA
AM1=48mA
Think about it -- If all the indicators are reading the same value what does that tell you?yes.
These values are imprecise to such an extent that I cannot be certain you calculated them correctly --- Granting, however, that your values are 'close enough' (was the circuit working properly):AM4=3mA
AM3=4+3=7mA
AM2=6+4+3=13mA
AM1=12+6+4+3=21mA
How do you reconcile that with the fact that all four indicators are reading 12 amperes?!?!the circuit is normal
Thread starter | Similar threads | Forum | Replies | Date |
Pull down Resitor vaule for npn transistor | General Electronics Chat | 6 | ||
Question,help with sinusoidal voltage | Homework Help | 17 | ||
M | OP amp question. Calculate the gain vi/vo. | Homework Help | 1 | |
A electronic circuit question ! | General Electronics Chat | 30 | ||
An Electronic Welder Circuit Question | General Electronics Chat | 3 |
