Electronic Circuit Question.
Discussion in 'Homework Help' started by RRITESH KAKKAR, Dec 24, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    how to know or calculate this.
    Which component is shorted?
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The current through R1 will be: 48mA calculated.
    sandeep mukke likes this.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Which component is open?
  4. hp1729
    Nov 23, 2015
    2,097
    232
    Not that resistors short out, but If R1 were shorted you would not see that 2.4 Amps through the following stages. Likewise R2 and R3, so it must be R4.
    RRITESH KAKKAR likes this.
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    In a 20 Vac series RC circuit, if 20 V is measured across the resistor and 40 V is measured across the capacitor, the applied voltage is:
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    i got the answer but don't understand 20Vac meaning here.
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    What is the angle theta value for a 5.6 [​IMG]F capacitor and a 50-ohm resistor in series with a 1.1 kHz, 5 Vac source?
    After solving:
    P Active power across R=0.5W
    Q Reactive C= 0.967VAR
    So, S=√(P²+Q²)
    S=1.10VA
    cosΦ=Base /hyp.
    cosΦ=0.5/1.10=62.9
    But answer is –27.3 degrees
  8. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,845
    1,314
    First you're going to have to tell me what the rectangles represent?:confused::confused::confused:
    If ammeters what is their terminal to terminal resistance?
  9. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,314
    @RRITESH KAKKAR --- You know full well how to calculate reactance and convert between rectangular and polar formats!:rolleyes::rolleyes::rolleyes:
  10. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Sinθ=imaginary(Reactive)/Real(Active)
    Sinθ=0.967/0.5=1.9 error
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    What is the phase shift between the voltage across the resistor and the voltage from the source?
  12. shteii01
    Feb 19, 2010
    3,500
    511
    Convert C1 into impedance.
    Now you have two "resistors" in series, also known as Voltage Divider.
    Apply voltage divider formula to R1 to find voltage across R1 in complex form.
    Extract the angle from the complex voltage of R1.
  13. JoeJester
    Apr 26, 2005
    3,401
    1,218
    Not to be particular but there is a little bit of difference between the 2.4 amperes you quoted and the 2.4 GigaAmperes the simulation shows. However, the troubleshooting was correct.
    Hypatia's Protege likes this.
  14. JoeJester
    Apr 26, 2005
    3,401
    1,218
  15. WBahn
    Mar 31, 2012
    18,087
    4,917
    RRITESH,
    PLEASE, one problem at a time (in a given thread). You posted several problems and have created utter chaos because no one can keep track of which problem a given response is for.
    Start ONE thread on ONE problem, provide YOUR best attempt to solve that ONE problem, and focus on that ONE problem until you understand the solution.
  16. WBahn
    Mar 31, 2012
    18,087
    4,917
    This makes no sense at all. Leaving aside the fact that your ammeters are should 2.4 GA (i.e., 2,400,000,000 amperes), the fact that they are all the same means NO current is flowing downward through ANY of the resistors that are connected between meters. Hence R1, R2, and R2 are ALL acting like open circuits. Then assuming that your 2.400G should be 2.400m, R4 is behaving like a 5 kΩ resistor.
  17. JoeJester
    Apr 26, 2005
    3,401
    1,218
    @RRITESH KAKKAR
    A more realistic problem for the first one would be stated like the attached as your simulations perfect supply is capable of GigaAmperes:
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    How to know there is no output seen?
    so, one does not know whether circuit working or not?
  19. #12
    Nov 30, 2010
    16,684
    7,322
    4 outputs are seen. They are labeled as 12A after each amp meter.
    YOU don't know, but only because you can't read the labels.
  20. Hypatia's Protege
    Mar 1, 2015
    2,845
    1,314
    Aye! That was my principal issue with the 'rectangular' blocks!:eek::eek::eek:
