Hi guys,
as you may or may not know, I play the bagpipes in a pipe band and it is something I really enjoy doing.
However, one downside is clearly the volume of the instrument - I can't practice late at night, for example.
One solution of this is to create an electronic version of the bagpipes known as an electronic chanter. This is basically a set of bagpipes without
drones or a bag - just the pipe which you play the notes.
I'm considering building one myself, just out of curiosity, but I have a few questions before I begin.
1. I'm not planning to make the sound produced sound like bagpipes - just for simplicity, I probably use some astable circuit producing square waves at different frequencies to simulate the different notes. Would I be able to use a 555 IC, linked to different preset pots. to 'tune' the instrument?
2. If I'm wanting a drone (ie more than one tone at the same time), I will need a seperate astable section for each. Is this correct?
3. With regards to re-creating the holes to create the melody - could i use two small pads which when bridged by a finger or thumb, complete the circuit? Perhaps using a darlington pair to increase sensitivity? I'm thinking that a mechanical switch would be too clumsy. Does anyone have any other suggestions?
4. Or do you think I'm going off in a totally wrong tangent? Perhaps I should consider using a PIC? Anything else?
As mentioned, I'm just considering this project. I'm try to take it slowly to avoid any mistakes (I'm sure I'll still make some) - so I don't have a schematic to show you. If you really want one, just say and I'll sort something out.
Thanks for your time.
