Electron vs fluid flow
Discussion in 'Feedback and Suggestions' started by Unregistered, Jun 30, 2010.
Thread Status:
Not open for further replies.
  1. Unregistered
    Thread Starter Guest
    Your analogy here: http://www.allaboutcircuits.com/vol_1/chpt_2/2.html is flawed. In a closed system with a pump pushing a constant volume of fluid, an increase in resistance would yield a decrease in pressure and an increase in flow velocity - flow and pressure being inversely proportional.
    DJ
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I don't agree, but you are welcome to register and discuss it in the other forums.
    Any increase in fluid flow resistance will (by definition) reduce flow velocity, since that is a fundamental definition of resistance, that is to resist movement. If you make a good argument then the book might be updated to reflect this.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Bill is quite correct - this subject can be pursued further if the OP cares to register.
Thread Status:
