Electron: -/+ Mc^2 <==> h* <==> hf.
Discussion in 'Physics' started by socratus, Nov 2, 2013.
  1. socratus
    Mar 26, 2012
    267
    In his 1924 doctoral work Louis de Broglie wrote that every
    quantum particle with energy E=M^2 is tied with wave's process
    by equality: Mc^2 = hf.
    In 1925 Goudsmit and Uhlenbeck wrote ( as a hypothesis) that
    electron must / can revolve around its diameter. This own electron's
    hypothetical rotation was named " spin (h*=h / 2pi ) ".
    In 1928 Dirac wrote his theory which showed :
    a) in nature must exist electron with negative energy: -E=Mc^2
    b) the hypothetical 'spin' is real process of electron's rotation.
    My conclusion.
    De Broglie wrote his equation as mathematical equality: Mc^2 = hf.
    But this equation shows some real process in nature,
    In this equality is hidden some real process.
    In Dirac's vacuum sea can be process when virtual particle with
    negative potential energy –E=Mc^2 using its own inner spin /
    impulse h* changes its condition and becomes real particle
    with energy: E=h*f.
    This process was called ' Quantum fluctuation': -/+ Mc^2 <==> hf,
    Socratus
  2. socratus
    Mar 26, 2012
    267
    The QT is 'fishy' by two reasons:
    we don't know the reference frame of QT,
    we don't know the geometrical form of quantum particle.
    All the best
    socratus
  3. socratus
    Mar 26, 2012
    267
    The problem
    If electron revolves around its diameter its speed
    is faster than constant speed of quantum of light ( c=1).
    And there is scientific taboo: ' nothing can move faster than c=1'
    The solution
    I say that is possible to see electron / quantum of light from two points of view:
    a) from Earth gravity point – the speed c=1 is maximally,
    b) from Vacuum point – the speed c=1 is minimally.
    ( then the theory of 'tachyon' can be used)
    All the best
    socratus
  4. socratus
    Mar 26, 2012
    267
    Making more precise.
    It is possible to see electron / quantum of light from two points of observetion:
    a) from Earth gravity point – the speed c=1 is maximal,
    b) from Vacuum point – the speed c=1 is minimal.
    ( then the theory of ' tachyon' can be used in the reason
    to explain the high frequency of quantum particles )
    socratus
  5. socratus
    Mar 26, 2012
    267
    We know electron by what it does, not by what it is.
    The simplest particle - electron has six ( 6 ) formulas
    E=h*f , e^2=ah*c , +E=Mc^2 and -E=Mc^2 ,
    In the simplest atom its energy is : E=-me^4/2h*^2= -13,6eV
    In interaction with vacuum electron’s energy is infinite: E= ∞
    We don't know: what are interactions between these formulas ?
    Therefore the situation is like to an old Indian story: what an elephant is.
    One blind man touched the elephant’s foot and said elephant looks like a column
    Other blind man touched the elephant’s tail and said elephant looks like a snake
    The third one touched the elephant’s stomach and said elephant looks like a ball
    The . . . . . . .. . .
    The electron was *touched* in different experiments from different sides
    but it seems that our knowledge of electron is similar to the * blind – knowledge*
    of elephant from this old Indian proverb.
    Robert Milliken, who measured a charge of electron, in his Nobel speech
    ( 1923) said, that he knew nothing about “ last essence of electron”.
