That's not the cause of the 'speed' of electricity but that's the subject of another thread.Exactly. It's the rate at which the electrons pass a given point which gives the 'speed' of electricity. It's a bit like watching people going through the turnstile at a football match. They come through very quickly, and the turnstile is going round like crazy. But if you watch one person moving with the queue outside, they are moving very slowly. But the O.P's instructor seems to be saying that the queue is actually moving in the opposite direction!
Ok if I start it will you explain more? I know it makes no difference to the practical results, but if the 'speed' of electricity is not about the number if electrons flowing past a certain point then I'm keen to know more. I thought that was how current was defined. That's the problem with science.. Every time you think you understand, it turns out that the truth is more complex still!That's not the cause of the 'speed' of electricity but that's the subject of another thread.
The number of charge carriers moving past a point (current) is a perfectly good way of describing the 'what' of electricity's effect on matter but it doesn't describe the 'why' very well.Ok if I start it will you explain more? I know it makes no difference to the practical results, but if the 'speed' of electricity is not about the number if electrons flowing past a certain point then I'm keen to know more. I thought that was how current was defined. That's the problem with science.. Every time you think you understand, it turns out that the truth is more complex still!
And the Wikipedia article is deficient because it neglect the fact that charge is a signed quantity. But note that they covered that by adding, "electrons are technically represented with a charge in negative coulombs, and protons positive". They also claim "for electrical purposes charge is generally represented with an absolute value". Even if this is true (and I'm not convinced it is), that is irrelevant because the sign is inextricably linked to this discussion, and therefore can't just casually be ignore.The Wikipedia article on Coulomb says "Since the charge of one electron is known to be about 1.60217657 × 10E-19 coulombs, a coulomb can also be considered to be the charge of roughly 6.241509324 × 10E18 electrons".
by Jake Hertz
by Duane Benson
by Jake Hertz
by Aaron Carman
