Electromagnetism
Discussion in 'Homework Help' started by user123456, Feb 26, 2014.
  1. user123456
    Jan 26, 2014
    12
    What is the force of attraction between a north and south pole separated by air? The flux density in the air is 0.84 Tesla and the rectangular poles measure 2cm by 3 cm. (168N)
    F = B^2/2u0
    0.84^2/2 x 1.257 x 10^-6
    Not getting 168Newtons, can anyone please give me a hand here?
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Could you show your work? With units?
    If
    F = B^2/(2μ0)
    What are the units on B?
    What are the units on μ0?
    What are the units when you divide the first by (twice) the second?
  3. jjw
    Member
    Dec 24, 2013
    174
    32
    The formula is missing something.
    Hint: the area of the magnetic poles has an effect to the force.
  4. user123456
    Jan 26, 2014
    12
    Thanks for your reply,
    I multiplied 2 x 3 = 6 cm, still not getting the right figure.
  5. studiot
    Nov 9, 2007
    5,005
    515
    cm are not SI units, you should be using metres.
    further 2cm x 3cm do not multiply to get 6cm.
  6. user123456
    Jan 26, 2014
    12
    2.66 x 10^-10 if i used meters.
  7. shteii01
    Feb 19, 2010
    3,500
    511
    lol
    AREA is squared.
    user123456 likes this.
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    Well, since the OP can't be troubled to answer these questions, I guess I will.
    The units on B are tesla, which is (Ns)/(Cm)
    The units on μ0 are H/m or N/(A^2)
    Thus, the units of B^2/(2μ0) are [(Ns)^2/(Cm)^2]*[(A^2)/N]
    which reduce to N/(m^2)
    Thus, a simple dimensional analysis reveals not only that the equation given simply cannot yield the desired answer, but gives a really strong indication of exactly what needs to be done in order to correct it.
    But, hey, units are just a troublesome bother that only waste time.
  9. jjw
    Member
    Dec 24, 2013
    174
    32
    Your result is about 10^-10 times too small.
    The constant 1.257 x 10^-6 should be in denominator.
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    <br />
F = \frac{B^2 A}{2 \mu_0}<br />
\ <br />
F = \frac{(0.84 T)^2 (2 cm \cdot 3 cm)}{2 \( 4\pi \cdot 10^{-7} \frac{N}{A^2} \)}<br />
\ <br />
F = \frac{ \( 0.84 \frac{Ns}{Cm} \)^2 (2 cm \cdot 3 cm)}{2 \( 4\pi \cdot 10^{-7} \frac{N}{\(C/s\)^2} \)}<br />
\ <br />
F = 1684000 \ \( \frac{ N^2 C^2 s^2 cm^2 }{N C^2 s^2 m^2} \)<br />
\ <br />
F = 1684000 \ \( \frac{ N \ cm^2 }{m^2} \)<br />
\ <br />
F = 1684000 \ \( \frac{ N \ cm^2 }{m^2} \) \cdot \( \frac{1 m}{100 cm} \)^2<br />
\ <br />
F = 168.4 N<br />
    See how wasting all that time on tracking units saves a lot of time?
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    You are right. That was an editing typo when doing a final fix-up of the LaTeX script.
    Thanks for catching it!
