Electromagnetism formula question
Discussion in 'Homework Help' started by Kai Jie, Sep 2, 2016.
  1. Kai Jie
    Jul 11, 2016
    Is the magnetic path length(L) equal to the mean circumference, 50π mm?
    If yes, then for question (c), should I skip it and go to question(d)&(e) to calculate (R) and (Fm), then only answer (c)?
    Also, please help check if all formula used is correct or not.
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    The magnetic path length is taken to be the mean circumference if the cross sectional area is constant and the material is uniform throughout.
    Kai Jie likes this.
  3. wayneh
    Sep 9, 2010
    12,388
    3,244
    Agreed. Think of it as the average length of all the various field lines. I suppose for an irregular cross section it would be the area-weighted average length. So if most of the material is at the outer perimeter, the average field line would be longer than if most of the cross section is at the inner edge.
    Kai Jie likes this.
  4. Kai Jie
    Jul 11, 2016
    Thanks for the help guys.
