Electromagnetic Induction Help Required
Discussion in 'The Projects Forum' started by erashish14, Mar 21, 2016.
  1. erashish14
    Apr 27, 2011
    Hi Experts,
    I'm doing an experiment of Electromagnetic Induction (producing current by changing magnetic field i.e. by circulating magnetic wheel of N52 Neodymium Magnets around copper coil),
    but what i found
    when the speed of wheel is HIGH, the Output Current is LOW (in range of .02 microAmp) &
    when wheel is about to stop i.e. when its speed is LOW, the Output Current is HIGH (in range of .11 microAmp)
    check the video once (),
    Kindly suggest where i'm doing wrong or what i need to change in my experiment, because as per Faraday's law, more frequent change in magnetic field produces more current, but its not seen in my experiment
    Kindly help
    Thanks in Advance
    Ashish
    "Solar Roof on Roads with Rain Water Harvesting & Advertisements"
    http://lightenmyways.blogspot.com/
  2. TheButtonThief
    Feb 26, 2011
    219
    38
    What load are you using? expect strange readings when you measure current with no load.
  3. blocco a spirale
    Jun 18, 2008
    1,457
    369
    Measurement error. I keep seeing the minus sign appearing on the meter, is it set to DC?
    GopherT likes this.
  4. GopherT
    Nov 23, 2012
    6,301
    4,020
    @erashish14
    Set your meter to AC volts.
    Try again.
    Then try with the coil of wire in different orientations (with hole of spool
    - left to right
    - front to back
    - top to bottom
  5. DickCappels
    Aug 21, 2008
    2,753
    665
    Per blocco, put your meter on an AC scale.
    You can increase the output by putting a magnetic core in the coil.
  6. hp1729
    Nov 23, 2015
    2,084
    232
    It takes a while for the meter to react. What does the output look like on a scope?
  7. Alec_t
    Sep 17, 2013
    5,966
    1,133
    Because each magnet in turn moves towards and then away from the coil the coil produces an AC voltage. The averaged reading on a DC scale will be zero.
