electromagnetic field
Discussion in 'General Electronics Chat' started by gabriel1234, Dec 14, 2011.
  1. gabriel1234
    Dec 6, 2011
    does anyone know if i were to combine two opposite electromagnetic fields together, also if i were to put together two electromagnetic fields. what would happpen and are there any resources i could read?
    much appreciated if someone would help :)
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. Your thread does not belong in this forum, so was moved to a more appropriate forum.
  3. crutschow
    Mar 14, 2008
    13,505
    3,376
    Electromagnetic fields are radio waves. How do you propose to "combine" them. Radio waves do not combine, they simply exist in the same space at the same time.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    That's pretty much how universal electric motors operate.
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Electromagnetic fields are vector fields, they add like vectors. They can cancel each other out. Any basic E and M book will cover all of this, or most introductory physics texts. This is true if they are static or dymanic ( like radio waves ). The two different fields are related to each other by equations know as Maxwell's equations.
  6. bountyhunter
    Sep 7, 2009
    2,498
    507
    According to Star Trek, it would be the end of the universe.....
    I think you would just get cancellation if the E fields are opposite polarity and equal magnitude.
  7. crutschow
    Mar 14, 2008
    13,505
    3,376
    Motors use magnetic fields.
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    Which are still electromagnetic at low frequency.
  9. crutschow
    Mar 14, 2008
    13,505
    3,376
    True in a strictly technical sense. But it's the magnetic part of the field that does the work. The electric part of the field has no effect on the motor operation.
