Hi everyone! Me and two friends of mind are doing an electromegnetic cooling system as a science project for school. The principle is the same as with a multi-stage coilgun, i.e multiple coils accelerating a projectile. There are some major differences though, the system being closed in a circulating path and the projectile made of (homemade) ferrofluid. The ferrofluid is then going to cool boiling water by passing through a refrigerant (dry ice) each lap. Due to the difficulties of optically trigger the coils, were going to calibrate preprogrammed on/off-switch times for each coil. We have no earlier experience in neither programming nor in using electrical components so we want to make it as simple as possible. Weve been restricted not to use more power than what we can get from the mains (230V, 10A), but were going to need all the juice possible.
We have been advised to use the following components by some robot-builders:
1 Arduino board (because of its simplicity, however, we dont know which model, but it must have the ability to control eight coils)
8 Capacitors 2000-4000uF, 300-400V
8 MOSFET transistors 2-3mOhm
8 MOSFET drives (model lm5110)
We have no idea how to put his puzzle together, which models to choose for best result and how to program it. Please help us!
