I trying to be creative in my free time so i am making an indicator which is triggered with an electromagnet .
I basicly have a plastic circle with a magnet glued on it. On the other side I have an electromagnet, and when current passed through the electromagnet it pushes the magnet glued on the circle(and with the help of some gravity).
The indicator when not triggered shows green field and then when triggered shows red..
It works fine...But do you maybe have an other idea for triggering with an electromagnet or maybe a complete redesign of the indicator...
Because if you shake the housing, sometimes the magnet drops away from the electromagnet when no current is passing through...
I am using an electromagnet from an relay...
I am always looking for improvements
One bad sketch...
One bad sketch...
