I have a broken firewall that went out at work the other day. I decided to bring it home and open it up to find the problem. Looks like the capacitors on the power supply decided to bust open and there is a big burn mark on the top of the case from it. I ordered new capacitors from Amazon, same uf and voltage but when they got here they are different physical sizes from the ones currently on the power supply. My question is, which I think I already know the answer to, does the physical size make a difference in the capacitor if the specs on them are the same?
Thanks in advance for your help and sorry for the dumb question - I am still searching on Amazon for the right CAPs to replace them with
