Electroless tin plating, electroplate tin and ferric chloride
Discussion in 'General Electronics Chat' started by Robin Mitchell, Dec 13, 2014.
  1. Robin Mitchell
    Oct 25, 2009
    738
    206
    Hi all,
    So I have sucessfully got through hole plating to work but I have hit a bump. I plate the holes using electroless tin plate (the chemical solution), and I have noticed that when the board is placed in ferric chloride the tin is tripped in seconds. Why is this? Does the same happen with electroplated tin? this also happens even if standard copper plated with the tin solution and then submerged in ferric chloride.
    Many thanks!
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
  3. BobTPH
    Jun 5, 2013
    806
    121
    Perhaps you should plate the holes through after etching.
    Bob
  4. Robin Mitchell
    Oct 25, 2009
    738
    206
    BobTPH,
    If I etch before tin plate the plated copper is removed.
