When you get electrocuted what causes the pain or death...
Is it the rate at which the current is flowing thru you.
The amount of voltage (i.e work/energy done on you)
or Is it the power the rate at which the work is being done on you?????
I seem to think you could have a big voltage put slow current if you have a great resistance. So is it the work done on you or the rate of the electrons flow.
