Electro tech help
Discussion in 'Homework Help' started by bthistle, Feb 12, 2008.
  1. bthistle
    Feb 12, 2008
    6
    This has to do with efficiency
    A pumping station raises 1600 kilograms of water a distance of 5 meters. if it has an efficiency of 75%, how much energy would be required?
    this is on my assignment i am puzzled haha
    thanks
    bill
  2. bthistle
    Feb 12, 2008
    6
    is it missing some givens? if i had the initial energy i could get somewhere, but it seems like this question is lacking some givens.
  3. bthistle
    Feb 12, 2008
    6
    i would show a attempt but not sure where to start.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Work = Force * Distance. With 75% efficiency, multiply times 1.333.
  5. scubasteve_911
    Dec 27, 2007
    1,202
    I'm no physics expert, so I may be incorrect. I believe work requires knowledge of the force involved, which is unknown in this case. You are only given that the potential energy of the water is raised.
    PE = mgh
    PE = Energy (in Joules)
    m = mass (in kilograms)
    g = gravitational acceleration of the earth (~9.8 m/sec2)
    h = height above earth's surface (in meters)
    Then compensate for efficiency.
    Steve
  6. bthistle
    Feb 12, 2008
    6
    so use PE = mgh and answer is in Joules per sec right?
    then convert to watts
    then use the formal for efficiency.
  7. scubasteve_911
    Dec 27, 2007
    1,202
    No, I don't think so. You asked for the energy required, not the power. Watts is a unit of power.
    You would consider power if you wanted to lift that load's potential energy in a certain amount of time, then you can figure out what sort of mechanical power you would need to do this.
    Steve
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Power is the rate at which energy is converted from one form to another. In this case, conversion is from electrical energy to 75% mechanical energy + 25% waste heat.
  9. scubasteve_911
    Dec 27, 2007
    1,202
    Here, there is no rate of energy, there is just potential energy. For example, as an object is raised against gravity, its potential energy increases. It doesn't matter at what rate this is happening, since that is a matter of power.
    This is my understanding anyways.
    Steve
