electro mechanical systems
Discussion in 'The Projects Forum' started by leghari, Jan 5, 2012.
  1. leghari
    Oct 15, 2011
    14
    Hi everyone I have a subject EMS(electro mechanical systems) can anyone suggest a project that i can make.I want a light project as I will be making it individually and I have 4 other projects to make for other subjects.please suggest some good projects.
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    an automated can crusher. pneumatic piston, solenoid valve, capacitive sensor, limit switch, microcontroller.
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    a battery, a switch, and a DC motor. Attach something on the motor shaft to give it that 'wow' affect.
  4. leghari
    Oct 15, 2011
    14
    Can you tell me more about limit switch(its sounds interesting).
    What about DC motor.......?? Do you mean I should make one?
  5. shortbus
    Sep 30, 2009
    4,094
    1,678
    Don't mean to be rude or offensive, but, what have you learned in class if you are asking these questions?
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    Limit switches are contacts placed on the edges of a moving part's range to detect that it has reached the end of its course. Usually that triggers a "brake" or a "reverse" action.
