Hi. I wanted to know if in a solid earthed neutral system where there is a neutral earth resistor at a primary substation, when there is a fault on an overhead line for example and a conductor is on the ground does the current flow through the mass of the earth back and through the neutral resistor to the source?? Is that correct that the current flows through the earth (the soil) ??
