Electrical
Discussion in 'General Electronics Chat' started by harman16, Apr 26, 2006.
  1. harman16
    Apr 26, 2006
    why a 2 Φ circuit does not exist?
  2. Grant
    Member
    Mar 5, 2006
    17
    We can use 2 phases together of a 3 phase supply to act as a single phase if it gives us the desired voltage we require for the equipment we want to power. This equipment is single phase- meaning the heating element or coil or lamp is run off just one phase, singular- "single phase".
    Cheers,
    Grant
  3. kubeek
    Sep 20, 2005
    4,691
    806
    In short because the two phases add up and act like a single phase.
    When you have a center-tapped supply transformer and take the center as a common point, then you have two phases, shifted by 180deg, on the opposite sides of the secondary. But when you take one end of the secondary as a common point, than you have just a single phase supply with two voltages.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    In brushless DC motors you want the phase with the current to be at 90 degrees or less away from the rotor, so that maximum torque can be applied while it is energized. In a two phase machine there is just no good way to satisfy this criteria.
  5. alim
    Dec 27, 2005
    113
    Hi 2 phase circuits were in existence before the advent of 3phase,in 2ph. the voltages are 90deg .out of phase .Kubeek refers to a centre tapped transformer as 2 ph. but that should be called a bi phase transformer.
