Electrical glue uses
Discussion in 'General Electronics Chat' started by Gdrumm, Oct 23, 2012.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    What applications might be suitable for using electrical glue, instead of solder?
    Thanks,
    Gary
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    What is "electrical glue"?
  3. Gdrumm
    Aug 29, 2008
    684
    36
    It is advertised as a no solder glue that conducts electricity.
    I found it on ebay.
    I was thinking of using it to solder (glue) batteries together for cordless drill pack repair.
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    Ebay sells garbage.
    I betcha the no solder glue does not stick things together well and does not conduct the many AMPs used by a cordless drill.
    Why do you think the drill manufacturer WELDs the battery cells together instead of using the gloooo?
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Bison also makes conductive glue.
    There is stated that it can not be used on power connections:
    To produce or fix electric conductive connections. Suitable to use on glass, metal, rubber and bakelite. Not suitable in case power will be used on the conductive connections.
    This comes from this page:
    http://www.nedis.com/Articles/Bison/SILVERGLUE.php
    Bertus
  6. takao21203
    Apr 28, 2012
    3,577
    463
    Yes this conductive silver paint has been along for quite a long while.
    There is also conductive epoxy. It is mainly used for PCB mount, film PCBs, SMD, etc.
    Not power electronics. You can try using a thin film! But don't expect much from it.
  7. chrissyp
    Aug 25, 2008
    82
    10
    conductive adhesives are good for repairing damaged pcb tracks or making delicate electrical connections where soldering would cause too much heat .It does stick things very well ( I am not guessing ,i've used it ), but i do not think it will be suitable for high current aplications.
  8. Bob T.
    Member
    Oct 22, 2012
    35
    this is good for fixing only.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    Conductive epoxy is also used in microelectronics, where it can be a power conductor. If the amps get high enough though, it is soldered.
  10. Gdrumm
    Aug 29, 2008
    684
    36
    Thanks for the feedback everyone.
    Gary
  11. electronewb
    Member
    Apr 24, 2012
    260
    I bought some of that conductive glue on ebay. It came in small containers of a few ounces each I used it to glue wires to batteries. Works OK but the glue dried after 2 months in the containers it was hard as a rock if you buy conductive glue buy the good stuff.
