Like the drawing below.@ronv OK, what I think your saying is instead of a normal pull up you would use a diode replace the pull up. That sounds like it would work! But would a resistor still be needed with the diode? Or being a logic level from the timer out put the resistor is not needed?
I think you have that backwards. Stuff in the gap (metal) makes it more prone to shorts not missing an arc. It is harder to start an arc than to keep it going. That's the whole purpose of the high voltage boost to try and get it to start more reliably.While the 'wait for an arc' seems like a bad thing, it really isn't. If the arc 'should' happen but doesn't it would usually mean the gap conditions have a problem. By waiting it gives the dielectric time to flush/clean the gap, which is the most common reason for no arc.
