Electrical conductivity via one wire.
Discussion in 'The Projects Forum' started by makrameniso, Jul 4, 2016.
  1. makrameniso
    Jul 4, 2016
    I would like to pay your attention, that i have to measure the liquid electrical conductivity via one wire.
    If you can resolve this, please reply to me.
    Please how can i manage this with Shooting a laser in, measure light degradation,or have a magnetic float and measure inductive coupling..
    Thank you .
  2. AlbertHall
    Jun 4, 2014
    2,252
    445
    You can't measure anything with one wire.
  3. Kermit2
    Feb 5, 2010
    3,838
    961
    Measure current flow.
    This will correlate to the resistance or conductivity of the liquid.
    You supply 10 volts and measure .000001 amp of current. Using ohms law what is the resistance?
  4. DGElder
    Member
    Apr 3, 2016
    347
    87
    Assuming the probe doesn't have a battery inside or a mini chem lab and assuming no other equipment is used beyond said wire, probe and circuit. Then use the probe as a monopole antennae and measure how the supplied power to the probe varies with changing liquid conductivity..
  5. DickCappels
    Aug 21, 2008
    2,746
    665
    Are you able to have a battery or other power source at the tank?
  6. BR-549
    Sep 22, 2013
    2,164
    415
    It would be dangerous to suggest a solution, without know the liquid and the environment.
    Is it water, gasoline or H2O2?
  7. shortbus
    Sep 30, 2009
    4,086
    1,664
    Sure you can. Cut a wire to a 1 meter length and measure the distance of something, one meter at a time.
    Sinus23, #12 and AnalogKid like this.
  8. BR-549
    Sep 22, 2013
    2,164
    415
    There usually is a spare conductor. Ground.
  9. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    Sure you can. Pump some RF into it, and the SWR will change as it goes from immersed to free space.
    ak
