Electric Shock!!!
Discussion in 'Feedback and Suggestions' started by steeve_wai, Sep 25, 2007.
  1. steeve_wai
    Thread Starter Active Member
    Sep 13, 2007
    47
    all about circuits states that "Electric shock can only occur when contact is made between two points of a circuit; when voltage is applied across a victim's body."
    so if i hold an overhead wire with both hands and hang from it without touching anything else,i wont get an electric shock ...right?
  2. recca02
    Apr 2, 2007
    1,211
    exactly!!
    there must be a path for electrons to complete the cicuit
    i;e to travel from higher potential to lower,
    if u touch the wire even with any of ur hand not necessarily both u are at the same potential as that of wire.
  3. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You are a high resistance path in parallel with the wire. Do the relevant maths using Ohm's Law and parallel resistor equations and this will demonstrate the point clearly.
    Dave
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Just ask all those squirrels and birds!:D
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Strangely enough, something I was explaining to my missus today as she commented that 'no birds had come near our new house'. Needless to say she didn't pay a blind bit of notice! :D
    Dave
  6. cumesoftware
    Apr 27, 2007
    1,330
    11
    Should the term shock aplly to a significant voltage/current? I mean, there is always a path that electron will biase, even if the source is a 12V battery (current will be very small, thought).
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
