electric shock question
Discussion in 'General Electronics Chat' started by maggie, Sep 5, 2011.
  1. maggie
    Aug 15, 2011
    13
    A power line came down on my street, and a neighbor went down and moved it out of the road. He believed it was safe, since the power was out in the houses up the line from the break. i don't know any more than he does, but my logic was, maybe there could still be enough voltage to kill a human, and maybe the transformer still has a charge, and it's just not a good idea to go near it. Now that he succeeded in moving it without a problem, he is even more convinced that he's right and I'm a big worry wart. This may be more an electrical issue than electronics, but maybe there's an EE out there willing to explain this to me.
  2. MrChips
    Oct 2, 2009
    12,622
    3,451
    If the power was out, there would be no residual electrical charge in the cable. However, if the power was being restored while he was in the process of moving the wire he probably would not see the light of day.
    You were correct. It is best to leave power lines to the proper folks to handle, power out or not.
  3. #12
    Nov 30, 2010
    16,655
    7,293
    On a more technical note, transformers do not retain charge, but capacitors are often used for phase compensation, and one of them could remain charged, depending on exactly which connections were destroyed and in what order.
    You were correct. There are people that do that kind of job safely, and it's not an average citizen. Even I would not touch a fallen power line, and I'm good at this!
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Handling of high voltage power lines is not a wise activity. The only safe assumption is that the line is potentially lethal. The safest thing to do is report the downed power line to your local power provider and let them deal with it.
    hgmjr
  5. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    That would have been extremely foolish. Often, local breakers are configured to try and automatically reset once or twice. Unless he knew without a doubt that the local switches were pulled, approaching the line would be foolish.
  6. steveb
    Jul 3, 2008
    2,433
    469
    There is not much to explain, other than the fact that your neighbor was stupid to touch the line. No EE in their right mind would have done that, no matter how good their understanding of electricity, and no matter what knowledge they had about the state of the voltage on the line.
    The people that work on those lines are highly trained and have the right tools for the job. It's that simple.
    Not too long ago I read about a high voltage line that went down. If i remember correctly, three people died. A father went out to look and was electrocuted even without touching the line. The son ran out to help him when he saw him fall and was also killed instantly. I believe one more person (maybe his wife) did the same and payed the ultimate price.
  7. Smoke_Maker
    Sep 24, 2007
    126
    15
    Ask your neighbor if he saw a big warm welcoming white light and tell him NOT to go into the light. :)
  8. bluebrakes
    Oct 17, 2009
    245
    7
    i've seen some nasty pictures of people being fried until all of their bodily fluid has been boiled out of their bodies due to their ignorance of the dangers of high voltage.
    You were right, a really dumb thing to do. He's going purely on assumptions and very stupid indeed.
  9. Adjuster
    Dec 26, 2010
    2,147
    300
    The fact that there was a power outage in the area does not guarantee that a given broken cable was dead at the time, nor that it would stay dead. For instance, unless he had very definite knowledge of what constitutes upstream and downstream in the system, how could this fellow be sure that it was not the disconnection of that very cable which had caused the fault in the first place?
    The point about fault restoration, automatic or otherwise, is a good one. Just thinking about it makes me feel uncomfortable.
  10. shortbus
    Sep 30, 2009
    4,082
    1,663
    To quote the off topic - wandering topic guru of AAC "Don't touch the Loosewire"
  11. Arius007
    Sep 2, 2011
    14
    As well as the risks already mentioned there is another system used on Medium/High Voltage lines called (in some places) auto-earthing - if it detects a line down it can connect that phase to earth. It can also reset itself if the conductor is removed from ground, so the line is at zero volts potential, you pick it up, the auto-earthing resets and you're left holding a HV cable.
    Something else not mentioned yet is Step Voltage which is the voltage that you can pick up between your two feet while being close to the conductor - it's not necessary to touch it to get fried!
    Bottom line is you don't touch it until you've solid confirmation that it's been properly isolated and you won't get this confirmation unless you're working for the company that owns the line.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    I think that's what steveb was suggesting in his anecdote in post #6
  13. Arius007
    Sep 2, 2011
    14
    It was indeed. I missed it.
  14. steveb
    Jul 3, 2008
    2,433
    469
    This is a subject where repetition is a very good thing. :)
  15. maggie
    Aug 15, 2011
    13
    Thanks to everyone who posted on this. You all gave me plenty of reasons I had not thought of. I think I discovered the difference between ignorance and stupidity. It's ignorant to do it the first time, but thinking that doing it once proves you know what you are doing, really shows lack of intelligence.
  16. cjdelphi
    Mar 26, 2009
    272
  17. maggie
    Aug 15, 2011
    13
    WoW! another not so bright idea. She might have lived but there was smoke coming out of her head! I'd like to know if there were any after effects. Maybe epileptic seizures, or crazy new math skills?
