MaxHeadRoom
- Joined Jul 18, 2013
- 28,684
The fact that he mentions the voltage collapses when a small resistor is connected indicates to me it is a leakage voltage and would not sustain any current!Max you can't ground a case that's 80 volts that's a big short to ground isolation transformer would work. If he use a resistor that could dump 80 volts but that's a band-aid.
Many pieces of equipment that are not double insulated and not grounded will exhibit this feature.
Most PC's are designed with a grounded case and should be used as such if and when possible.
Max.
