Have A 24 volt Ac transformer operating latching relays. Need to operate 16 volt AC switching coils on the same circut,what reistor or reistors do I need to lower the voltage on the coil side of the switch. Thanks for any help.
This depends on what the relay coil's operating current @ 16V is. You can measure this or you can measure the resistance of the coil (POWER OFF) to determine it. When you know either value please post it and you will get a quick answer.Have A 24 volt Ac transformer operating latching relays. Need to operate 16 volt AC switching coils on the same circut,what reistor or reistors do I need to lower the voltage on the coil side of the switch. Thanks for any help.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Aaron Carman
