Electric motor malfunction
Discussion in 'General Electronics Chat' started by Billtull, Apr 30, 2015.
  1. Billtull
    Apr 30, 2015
    27
    have a hexcopter, I built it but it never flew, I burned up 8 motors or more, I put an 11.1 v 25 c battery on it, I bought 1000 kv 12 volt max motors for it a kk2.1.5 flight controller , 6 Electronic speed controllers, My Problem is 1.)i keep frying the motors 2.) I rarly see all motors spinning at the same time, so it always crashes before level flight, now, I decided that it was pulling so much current that it couldnt deliver enogh power to all 6 motors so, I put in 3 ohm resistors to lower the current going to the speed controllers and then motors, a modest 3 ohms, fried them emediatly, what should I do to make this work, anyone got an idea?
  2. Reloadron
    Jan 15, 2015
    1,053
    275
    I would start with posting a schematic and data sheets for the motors.
    What exactly is a 1000 kv 12 volt max motor? More information, data sheets and pictures would go a long way in getting help.
    Ron
  3. Billtull
    Apr 30, 2015
    27
  4. Billtull
    Apr 30, 2015
    27
  5. Billtull
    Apr 30, 2015
    27
    SUNNYSKY-Angel-A2212-2212-980KV-Brushless-Motor-for-Multi-copter-KK-QuadCopter
  6. BR-549
    Sep 22, 2013
    2,178
    419
    Have you ever done anything like this before?
  7. Billtull
    Apr 30, 2015
    27
    yup, i got 10.45 props on
  8. Billtull
    Apr 30, 2015
    27
    no not before, im a noob, an old noob, 55
  9. Billtull
    Apr 30, 2015
    27
    we didnt reallly have standard ways of doing stuff when i started, i tore apart and repaired some tvs, went to appliance repair school, wasing mashins, dryers electric ranges toasters etc
  10. Billtull
    Apr 30, 2015
    27
    hahaa my typing is not so good toooo.....
  11. Billtull
    Apr 30, 2015
    27
    I do know the ole e/i=r stuff but thats about it
  12. Billtull
    Apr 30, 2015
    27
    I was a jet mechanic when i was 20 something and i know mass x force= acceleration but its not helping me here thou
  13. Billtull
    Apr 30, 2015
    27
    Here is the only data I got for the motors
    Specification:
    Name: SUNNYSKY Angel A2212-980KV Brushless Motor
    Model: A-2212
    KV (rpm/v): 980
    Stator diameter: 22mm
    Stator length: 12mm
    Shaft Diameter: 3mm
    Motor size: Φ27 × 30mm
    No.of cells(Lipo): 2-3s
    Maximum Continuous Current: 14.5A/180s
    Max efficiency current: (4-9A)>80%
    No load current / 10V: 0.5A
    Internal resistance: 120MΩ
    Motor weight: 50g
  14. Reloadron
    Jan 15, 2015
    1,053
    275
    Well I did manage to fine this:
    Depending on the configuration these motors can draw some serious current. You mention the motors were burning up? I don't see how as long as the supply voltage is correct. The fact that all 6 do not spin up together would have me looking at the motor controllers and the flight controller.
    Ron
  15. Billtull
    Apr 30, 2015
    27
    here is the data for the electronic speed controllers
    • Constant Current: 30A
    • Input Volt: 6V - 12V
    • Max Current: 40A
    • Low-Voltage Cutoff: Auto detect and set
    Specifications:
    • High rate PWM
    • Low resistence
    • Sixteen cells Max (with BEC disabled)
    • User programmable brake
    • Low voltage auto setting based on battery
    • Throttle range self-adjusting
    • Soft start ramp up
    • Auto motor cutoff with reset
    • Runs motor in forward or reverse
    • Safe power arming program ensures motor will not run accidentally after turn on
    • Low torque start
    • Auto shut down when signal is lost
    kk2 board specs
    Specs:
    Size: 50.5mm x 50.5mm x 12mm
    Weight: 21 gram (Inc Piezo buzzer)
    IC: Atmega644 PA
    Gyro/Acc: 6050MPU InvenSense Inc.
    Auto-level: Yes
    Input Voltage: 4.8-6.0V
    AVR interface: standard 6 pin.
    Signal from Receiver: 1520us (5 channels)
    Signal to ESC: 1520us
    Firmware Version: 1.9S:pre-installed firmware.
    Dualcopter
    Tricopter
    Y6
    Quadcopter +
    Quadcopter X
    Hexcopter +
    Hexcopter X
    Octocopter +
    Octocopter X
    X8 +
    X8 X
    H8
    H6
    V8
    V6
    Aero 1S Aileron
    Aero 2S Aileron
    Flying Wing
    Singlecopter 2M 2S
    Singlecopter 1M 4S
    Firmware is 1.9S1.
    Package size: 10 * 10 * 3 cm / 4 * 4 * 1.2 in
    Package weight: 40 g / 1.45 oz
  16. Billtull
    Apr 30, 2015
    27
    its all pretty simple construction but just doesnt work.
  17. BR-549
    Sep 22, 2013
    2,178
    419
    But you have done this before and it did work.....right?
  18. Billtull
    Apr 30, 2015
    27
    watched many videos on how to do it but, thats wher it ends till you get to the PI settings and reciever settings, did that , bought the T-shirt, not happening....
    i can get 4 or 5 motors running at the same time but not 6, put the quadcopter 4 motors together, same problem, something is missing
  19. Billtull
    Apr 30, 2015
    27
    not yet
  20. Billtull
    Apr 30, 2015
    27
