Greetings,
Just bought a stalled Rascal Mobility Scooter 260le. I am an older dude looking for pros who can give me advice as I start this project. I have had an Invacare L3 for about ten months and runs like a champ but looking for something bigger around the outside. I acquired a Rascal 260LE with an electrical problem in addition to the speed and direction lever is missing a return spring or something. Someone before me tried to fix the unknown problems and gave up. Put everything back, screwed everything back together and removed the batteries for storage. I have a nearly new set of batteries in great shape but haven't hooked them up yet. I have been told it has sat in a spare bedroom for at least five years. We did push it out of a bedroom. Looks brand new, not a scratch. Thanks George..
Progress report: I have stripped off the seat, covers, baskets, and laid the wires, plugs, etc bare.
(A) I have noted the above speed/direction handlebar paddle is screw loose and seems to be missing maybe a small return spring, or rubber band. Everything in the compartment appears to be clean and intact. Can't see anything missing or damaged. Following the wire combo down the rod, under the deck and into the battery/control box compartment seems to be like new and no damage.
The control box is a black metal 5x5x2 not unlike what you would use as a junction box in home construction. It has a mother board on the bottom. The breaker was unscrewed from the box and lay in the box. The fuse holder was unscrewed from the box and coiled inside. Everything seems to be clean and OK except a pushed into the box wall 6 prongs with all wires running down to the various parts on the board is missing on the outside plug. Can't seem to find where it connects to at this point.
Well that’s it so far.
Thanks George
Thanks George
