Electric Heater controlling circuit using MOSFET or TRIAC
Discussion in 'The Projects Forum' started by omerdanish, Dec 16, 2015.
  1. omerdanish
    Oct 29, 2015
    I want to control Electric Heater which operates at 220AC Volts & Power is upto 2000watts. How can I control it by using Triac or Mosfet?
    If yes, then provide me a circuit diagram of it.. Thank you!
  2. Dodgydave
    Jun 22, 2012
    5,150
    769
  3. ScottWang
    Aug 23, 2012
    4,930
    777
    The single triac can't provide 2KW for the load, if you don't have much ee experience then you better to find and buy not to build, because it needs more triacs to in parallel with and that it will also needs the ee tech, otherwise you may damage a lot of triac during the experiments.
  4. Sensacell
    Jun 19, 2012
    1,183
    276
