electric guitar pick-up
Discussion in 'General Electronics Chat' started by MDK, Jun 25, 2008.
  1. MDK
    Feb 1, 2008
    22
    I just mde a electric guitar nd i was wondering what to connect the pick-up to besides the amp? because it buzes even with shielded audio cable?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    You did connect the shield to ground at one end, yes?
    Can you share the manufacturer and model of the pickup?
  3. MDK
    Feb 1, 2008
    22
    yes i did connect it to the ground.
    It is a fender i'am not sure of the model but it said strat
  4. acebodge1
    Member
    Jun 18, 2008
    13
    Hiya,i would try turning down preamp,and turning main volume up,also keep clear of flouresent lights,they cause me noise problems with guitar/radio.Also an effects unit with `noise gate` cuts out buzzes.
    regards bodger
  5. howard
    Jun 22, 2008
    If you have a metal bridge you might try to
    hook a wire to ground shield to it.
  6. blocco a spirale
    Jun 18, 2008
    1,463
    372
    Have you checked the ground connection to the input socket within the amp? Is the input socket OK? Do you have continuity between guitar ground and amplifier ground?
